EXEC vi - Windows
(WinNT, LabView 5.1)
Problem: when I wire the string name of the "program" to run to this vi,
nothing happens, & get error #42.
(The VI is in "Communication" or "Advanced" I forget which)
The program which I want to "run" is really a script compiled by another
program (V++). ie, the extension of the file is ".icl" which is
registered to V++. The script *wil*l run when I either double-click on
it, or type the name of it from the RUN PROGRAM window (under START)
Things I have tried:
-I have added the directory containing the script to the PATH
environment variable under WinNT system
-I have hardwired the entire path into the string input of the EXEC vi.
-When I wire a known-run-able string such as "notepad" to the EXEC vi...
it works
-Having V++ both open, and closed when I try this
-Running both "minimized" as true and false as the optional VI input
Any ideas?
Is this perhaps a registry issue? or only "windows" executables (with
..com .exe etc) can be run using "EXEC.vi"?
Thanks in advance...
-Helen
I have enough money to last me the rest of my life, unless I buy
something. -Jackie Mason (1931-)
(3,385 Views)
Helen,
I've run into the same thing, and I did a quick fix. I created a batch
file (*.bat) that contained the path of the executing program and then
the filename to open after it. Heck, even LabVIEW can create the .bat
file if it needs to be dynamic. Then call the .bat file from the exec
VI-it knows how to execute a batch file. Try that. It's a quick fix.
Mark
In article <39A170FA.E8543E04@erim-int.com>,
vi,
another
on
vi.
vi...
> it works!
> Any ideas?
> -Helen
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,382 Views)
Try putting "start" in front and putting the command inside quote marks.
i.e.
start "c:\myscript.icl"
Darren.
>(WinNT, LabView 5.1)>>Problem: when I wire the string name of the "program"
to run to this vi,>nothing happens, & get error #42.>(The VI is in "Communication"
or "Advanced" I forget which)>>The program which I want to "run" is really
a script compiled by another>program (V++). ie, the extension of the file
is ".icl" which is>registered to V++. The script *wil*l run when I either
double-click on>it, or type the name of it from the RUN PROGRAM window (under
START)>>Things I have tried:>>-I have added the directory containing the
script to the PATH>environment variable under WinNT system>-I have hardwir
ed
the entire path into the string input of the EXEC vi.>-When I wire a known-run-able
string such as "notepad" to the EXEC vi...>it works!>-Having V++ both open,
and closed when I try this>-Running both "minimized" as true and false as
the optional VI input>>Any ideas?>Is this perhaps a registry issue? or only
"windows" executables (with>..com .exe etc) can be run using "EXEC.vi"?>>>Thanks
in advance...>-Helen>-->>>I have enough money to last me the rest of my life,
unless I buy>something. -Jackie Mason (1931-)>>
(3,382 Views)
