EV3 Color Sensor
I am going to Use EV3 Color Sensor From Mindstorms .. My Question is Should I buy The Intelligent brick or can I communicate the sensor directly to labview Using DAQ or Myrio ?
(3,722 Views)
Accepted by topic author El-Awny
You will need the Intelligent Brick in order to program the robot. The Intelligent Block is essentially the brain of the robot and can be programmed to control the color sensor. Code can be written in LabVIEW (and a few other programming languages) and downloaded to the block. The block also supports USB, Bluetooth, and Wi-Fi communication.
Looking at the specifications of the EV3 Color Sensor, it doesn't seem to support any other direct type of communication.
Cici Z.
(3,668 Views)
