ERROR
Hello!!
I have made this program where I introduce a code number and the program checks if the length is okey and if the code number is in the database. If the code number is in the database, the program has to return the coding that appears in the database.
Message 1 of 14
(5,145 Views)
My problem is that the program doesn´t work.
Can you help me please
Message 2 of 14
(5,143 Views)
There are three kinds of error: syntax errors, logical mistakes and run-time errors. (Logical errors are also known as semantic errors). We discussed syntax mistakes in our word on records type errors. Generally mistakes are labeled into three types: systematic errors, random errors and error
Message 3 of 14
(5,128 Views)
The problem is that I don´t know how to correct them. Can you help me please
Message 4 of 14
(5,124 Views)
Hi 99,
You need to debug your VI…
Message 5 of 14
(5,106 Views)
I have tryed to put break points and the problem is in the case " Fin OK" that the subvi doesn´t work. I have also tryed to check if the subvi works okey running apart and it works okey.
Message 6 of 14
(5,103 Views)
Hi 99,
one possible problem is easily visible after you use AutoCleanup in each of those 3 VIs.
Why didn't you notice that problem on your own?
Message 7 of 14
(5,099 Views)
Sorry I´m new at Labview. I tryed doing the clean up but it doesn´t work.
Sorry
Message 8 of 14
(5,095 Views)
Hi 99,
Did you notice those "Training resources" in the header of the LabVIEW board? You really should use them!
That AutoCleanup button is not working for you? Why not?
(You don't notice that you placed the same subVI twice in your mainVI?)
Message 9 of 14
(5,093 Views)
The problem is in the subVI 4 but I don´t know where
Message 10 of 14
(5,071 Views)
