ERROR 1055 with NI DSC
Hi...
While building EXE in LabVIEW 2023Q1 (32 Bit) 23.1f276 the below mentioned error is obtained.NI DSC 2023Q1 is also installed in the system. NI DSC is used for data logging/alarm logging in CITADEL database.
After uninstalling NI DSC module error is not obtained.
Please suggest the possible methods to create EXE along with NI DSC.
Error 1055 occurred at Property Node in VISL_findDependentVISvr.vi->VISL_findAndProcessVISvrList.vi->VISL_detectAndCopyVISvr.vi->AB_Engine_Copy_CustomIOServer_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->Build Wrapper.vi->Build Wrapper.vi.ACBRProxyCaller.DF300056
Possible reason(s):
LabVIEW: (Hex 0x41F) Object reference is invalid.
Thanks....
(1,489 Views)
Hi Sajeesh
What step you are following. Please share
Regards
asif
(1,437 Views)
Hi
Enable Enhanced DSC Run time support is enabled
(1,416 Views)
Check out this answer:
https://forums.ni.com/t5/LabVIEW/Application-builder-error-1055/m-p/4311543#M1260927
Rolf Kalbermatter  My Blog
(1,406 Views)
