EPICS Server I/O server issue
Hi all,
my question regards Labview 2012 with DSC/Realtime modules.
I have noticed in that the EPICS server deploys read-only varialbes although I have specifed read/write everywhere. Indeed i can not modify varables from EPICS clients.
Thanks in advance,
Alessandro
(2,967 Views)
Hello Andrea,
I tried to do the same and I didn't get your error...
could you please tell me better what have you done? how did you create everything?
In the mean time I can suggest you to take a look at this link:
Interactively configuring an EPICS Client & Server Using LabVIEW DSC Module
https://decibel.ni.com/content/docs/DOC-22825
I hope it helps,
Valerio S.
(2,889 Views)
Hi Valerio,
I guess you did a mistake with my name Smiley Very Happy .
I followed every step, althught variables seem in only read mode, you can access to read/write them so there is no problem. Unfortunaly I gave up due to some limitations that I have encountered. For instance the array types, the only type supported seems ~16K of double while in my application I need ~250K of uint8.
Anyway thanks a lot,
Alessandro
(2,881 Views)
