01-25-2013
09:51 AM
- last edited on
08-07-2026
09:19 AM
by
Content Cleaner
I have downloaded and installed the LabVIEW EPICS Client I/O Server add-on for LabVIEW 2011. I do not use
LabVIEW DSC or RT. I followed the instructions here:
http://joule.ni.com/nidu/cds/view/p/id/2533/lang/en
I test it with a new empty project. , select My Computer-> New-> I/O Server and then in the "Create New I/O Server" window
select "EPICS Client", then press "Continue...". Nothing happens. The expected window labeled "Configure EPICS Server I/O Server"
never appears.
Multiple attempts after reboots etc. make no difference. Nothing happens after clicking "Continue...". Switching firewall on/off
makes no difference.
But when I do the same thing on a colleague's PC, the "Configure EPICS Server I/O Server" window appears, and I can configure
and use the EPICS Shared Variables OK. The same download file had been installed as on my machine.
We are both running the same version of LabVIEW (2011), the same version of Windows (XP) and have checked
that we have the same set of NI software installed.
Any suggestions as to how I might track down what is different about my PC that causes the problem? Is there some
aspect of the configuration of O/S or LabVIEW which might have this effect?
01-30-2013 03:00 AM
Hi PipT,
I'm investigating this for you and currently cannot see any reason why this would happen.
Could you clarify the following:
-Did you install the EPICS Client I/O server add-on with any anti-virus turned off?
-Does this issue happen for any other I/O server, or is it only for an EPICS client?
-Did either PC have any previous NI software installed, before being updated to this configuration?
