EOF
we have a problem with "Read from measurement file" block. It's inside a while cycle. When we save a file and try to read the first time everything works, but the following times the block gives us the error "End of file". We tried to modify the internal code of the block, to bypass the error signal, but we failed. Do you have any suggestion?
(2,976 Views)
Hi Micrel,
it seems that there isn't a simple workaround using express vi but take a look at this post, you can find a good solution.
http://forums.ni.com/ni/board/message?board.id=170&message.id=193618&requireLogin=False
Take a look also to:
http://forums.ni.com/ni/board/message?board.id=170&message.id=149239&requireLogin=False
Clara
(2,948 Views)
