E8801A Instrument I/O Assistant Queries with SCPI commands not working sometimes
It shows up as a com port. 🙂
Message 11 of 17
(1,429 Views)
If it shows up in MAX, you can communicate with it.  Have you tried communicating through MAX?  (Don't forget to terminate each cmmand with the \n like in the *IDN?\n example when you open up the VISA communicator.)
Were you successful with MAX?
Bill
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(1,417 Views)
Dear Frostwing, please contact Prologix support (support@prologix.biz) off list. Thanks.
Message 13 of 17
(1,380 Views)
my problems are just the same. I am using the Progolix GPIB-USB Controller 4.2. I can communicate with it in MAX. The write and read functions in the register "Basic I/O" work fine.
The problem is when i try to make the same with my own vi.
My programm starts with the vi open Visa -> write(serial) -> read (serial) -> close Visa. The write vi gets the same input like the Basic I/O in MAX: "id?\n" but i do not get an answer.
Does anybody has an idea how to solve the problem.
I hope someone can help and i know that most of you think i should by a "real" GPIB USB Controller, but i have this one already.
Best regards
Message 14 of 17
(1,208 Views)
You perhaps only think you are sending \n. Did you turn on '\' Codes Display? You should attach code when you are having problems. Is this also with the E8801A?
Message 15 of 17
(1,196 Views)
Also, id? is an invalid command.
Message 16 of 17
(1,190 Views)
first of all thank you for your answers. Secondly shame on me i was blind and got the wrong thread. To be honest i do not even know what E8801A means. Sorry for that.
But for the sake of completeness i think i should post the solution for my problem though it isn't a real solution. Blind as i am i could not find/search for the right example vi. By looking at the example "advanced_serial_write_and_read.vi" i could see how to do it with sending the "\n" in the right way.
Best regards
Message 17 of 17
(1,149 Views)
