E-mail by using labVeiw
Hi everybody
I am working on a school project. I'm going to send an e-mail by using labView. Is it possible to get a step by step information.
Is it possible to convert the e-mail into a SMS? In case how?
Mona
(3,570 Views)
Hello mona:
If your copy of LabVIEW is a Full Development System, then you have a "SMTP Send Message.vi"
With regards to sending SMS, it will depend on your hardware; probably if you have a cellphone attached you your computer, then you can create vi's that can communicate with it.
I hope this helps. Please inform me if you have further questions.
(3,563 Views)
Attached is a (v7.0) library that has worked for me.
(3,543 Views)
Hay!!!!,
Here is a better one.(LV 7.1)
ohiofudu
Certified LabVIEW Architect
Certified TestStand Architect
(3,531 Views)
hello Ohiofudo!
Thank you for the example. But I cant run it, because it misses several vi`s. (I think).
The names of the missing vi`s are:
OGIC_SMPT_initializeServer.vi
OGIC_SMPT_SendCommand.vi
OGIC_SMPT_ServerLogin.vi
OGIC_SMPT_SendData.vi
Mona
(3,506 Views)
I would recommend that you use the examples that ships with LabVIEW 7.1, e.g the "EMail with Data.vi", or the "E-Mail Notification.vi". Both are located in C:\Programfiler\National Instruments\LabVIEW 7.1\examples\comm\smtpex.llb\. Or
The only "tricky" part is to find the name of your mail server; you can get this from your IT Administrator.
FS
(3,468 Views)
