08-24-2011 09:39 AM
I am successfully opening VIs at runtime on a LabView RT system via "Open VI Reference". Usually these VIs contains various VIs from the standard palettes, like RT-FIFO. I am building LLBs that contain the main VI and my custom-made SubVIs.
But as soon as I am adding "Control Design and Simulation" VIs (e. g. integrator) to the dynamically loaded VIs, I get bombed with 1003 errors.
Workaround at the moment is to include the "vi.lib" in the LLB. But this leads to a huge filesize (16 MB or bigger), it's highly redundant and the build process takes a lot of time.
The "Control Design and Simulation" module is already installed on the RT system. Why are the simulation VIs not found there but other standard VIs (like RT-FIFO) are found?
08-25-2011
03:48 AM
- last edited on
11-18-2025
08:30 AM
by
Content Cleaner
Hi
Problem is not all VIs are installed with the driver package or other distributions on the Real-Time target.
That means not all the VIs installed on your computer are also available on the Real-Time target.
So you have to either always inlcude the missing VIs or building a source distribution.
Error 1003 When Using VI Server in a LabVIEW Application
Hope that helps.
Kind regards
Pixar
