Dynamically changing the scale name
I'm having problems finding the correct properties to modify for a mixed signal graph.
Basically I would like to change the name of a Y scale programatically (image).
Y scale name change
Would appreciate very much if someone kindly show me which property to edit.
Thanks very much!
(3,125 Views)
Accepted by topic author Will1989
Try to check this..
Silver_Shaper | CLD
(3,116 Views)
Thanks so much SaC! Finally!
Just to document the method for the benefit of other users:
How to rename scale name for mixed signal graph:
To select the y-scale, use the ActYScl property:
Create - Property Node - Active Y Scale
To change the text of the scale name:
Create - Property Node - Y Scale - Name Label - Text
(3,095 Views)
