Dynamic dispatch not calling child classes
I am trying my first efforts at OOP with a simple HAL architecture. I am working in LV2018 SP1.
Top level: Instrument.class
  • Class data is a VISA resource and two Win32 handles - all have accessors
  • has Config.vi and Reset.vi which are set as must-override in the class properties (these are empty placeholders)
Second level: I2C Interface.class
  • Inherits from Instrument.class
  • Class data has some I2C-specific values (pull-ups, clock speed) - all have accessors
Third level: Aardvark.class
  • Inherits from I2C Interface.class
  • Class data has a Win32 handle - has accessors
  • has fully-fleshed-out Config.vi and Reset.vi functions
In my application, I:
  • Take an Aardvark class and change it to I2C Instrument (using To More Specific Class.vi)
  • Call I2C Interface.class:Reset.vi (which should dynamically dispatch to Aardvark.class:Reset.vi)
  • Call I2C Interface.class:Config.vi (which should dynamically dispatch to Aardvark.class:Config.vi)
If I double-click on I2C Intstrument.class:Reset.vi and I2C Instrument.class:Config.vi, I get the Select Implementation windows with the down-arrow and the correct child class functions visible and selectable. This leads me to believe that the dynamic dispatch is configured correctly.
When I breakpoint the Aardvark.class:Reset.vi and Aardvark.class:Config.vi classes and run, they are never executed.
When I breakpoint I2C Instrument.class:Reset.vi and I2C Instrument.class:Config.vi and run, these classes execute. Dynamic dispatch is not occurring.
I have tried both loading the Aardvark class from disk (Get LV Class Default Value) and by using a class constant directly on the block diagram. Neither method seems to allow dynamic dispatch to happen.
What might I be missing here? I have attached my source distribution to this message and would appreciate some guidance.
(3,003 Views)
Accepted by topic author Madmanguruman
You're missing a shift register.  Writing to the Local variable doesn't do anything because it doesn't loop back around and change the input object.
Do this:
(2,986 Views)
So obvious. I keep forgetting that LV OOP is by-value and not by-reference, and I keep thinking of the classes as referenced objects and not "actual" objects. Thanks for the tip.
(2,944 Views)
