Dynamic control questions?!!
Dear all, I got one problem when I used the PID control toolkit to obtain the dynamic control response. When, I input the sinusoidal signal to the system under PID control, the frequency for the output signal is 5 times larger than the input. For example, when I input frequency 0.1 Hz, the frequency of the  output signal is 0.5 Hz. I do not know why, and the frequency shouldn't be changed. Amplitude and phase may change. the attachment photo is the block diagram and the program files can be running when they are put in the same directory.
Thx!!
Message Edited by SarahM on 05-21-2007 07:50 AM
(4,105 Views)
Pls do me a favor
Thx
(4,063 Views)
It all depends on your tuning.  It is possible to have a steady state input, but oscillating output.
(4,035 Views)
Hi, my problem is when I input one sinusoidal signal with one frequency of 0.1Hz to the PID control system, the frequency of output sinewave always 5 times faster than that of the input and the programs are the attachments. However, the frequency should not be changed anyway according to the theories. I can not find where the problem is.
(4,013 Views)
Could you show me the parameters you used?
LabVIEW 8.20程序设计从入门到精通已经出版,敬请关注!
欢迎访问LabVIEW学习乐园: http://labviewstudy.blog.edu.cn
(3,999 Views)
sure! The amplitude and frequency of the sinusoidal signal is 0.5, 0.5Hz respectively, while , the PID control parameters are Kp=0.8, Ti=5.2 and Td=0.4.
(3,994 Views)
abc-123,
    I just wanted to let you know that we removed the code in your previous post (PID dynamic.zip).  This contained your VIs but it also contained some of the VIs from our licensed and purchasable PID toolkit.  In our Terms of Use under Intellectual Property and Your Condict it references posting protected software.  These VIs from our toolkit cannot be posted on the forums, but feel free to repost your own code.  Thank you!
-Allison S.
Calibration Services
Product Support Engineer
(3,936 Views)
