‎06-18-2007 04:30 AM
‎06-18-2007 08:48 AM
‎06-18-2007 02:38 PM
Someone here mentioned those vi's so I'm going to try and do a bit of investigation with them and see what I can come up with - had a brief look and it didn't seem to do that much so I assume that I was using them in the wrong way - and there is another problem, and that is that we have certain standalone LabVIEW vi's that do things such as calibrating power meters and it's going to be a bit of a bummer if I have to constantly pass in the TestStand sequence context to these vi's just to get them to appear on top of TestStand as then they won't be particularly standalone and it means changing alot of VI interfaces which is going to upset a lot of people!
I'll have a play about with them tomorrow and see what I can do with them, but Ideally I'm looking for a standalone solution whereby I can have a bit of code encapsulated within the bespoke LabVIEW dialogues that just ensures that whenever they get called be it from LabVIEW or TestStand, they are always on top.
Many thanks for your reply, and I'll get back to you when I know a bit more,
‎06-18-2007 03:27 PM
‎06-29-2007 04:29 AM
Hi Dennis,
In the end found an even easier way of doing this - you just use the 'Bring To Front' method of the VI Server.App class and that seems to do the job.
