Dynamic Events - Output for Event Structure
I created some user events, I wonder if its possible to have outputs inside the Event structure for dynamic events.
Like the application event below.
If yes, how can i accomplish this?
Many thanks!
Message 1 of 12
(4,541 Views)
Hi j3r3mi,
see this link please. It should help you.
Mike
Message 2 of 12
(4,538 Views)
Thanks Mike, but i din't think thats what i wanted. Basically, the link just illustrate how events are used (which i think i already knew). However to go deeper, which i wanted to have an "output" (or filter, or whatever u named it) in the Event Structure for my Dynamic User Event. I guess thats impossible as i have trying it whole day and searching the web & forum for an answer.
ANYWAY, MANY THANKS!! 😄
Message 3 of 12
(4,532 Views)
sorry, i didn't realized that you mean output.
Why is it necessary to filter a user event. If you don't want it, then simply don't send it. Can you explain what you like to do?
Mike
Message 4 of 12
(4,528 Views)
I have an event (say Event A) which is trigger perodically. In the event structure (for the case ,Event A), some data is being passed back to the VI which triggers that event.
If you know C program, its similar concept as a callback function.
int GetData(int *_val)
    if (_val)
        _val = 9898;
//// main code
void main(void)
    int success = 0;
    int myData = 0;
    while (1)
        success = GetData(&myData);
Message 5 of 12
(4,521 Views)
why do you want to use the Event Structure? You can realize it with a queue or a notifier or you can use a sub vi which you call by reference.
Can you show what you try to to in LabVIEW. With a specific example it would be much easier to find a solution for you.
Mike
Message 6 of 12
(4,516 Views)
I know there are many ways to go about it. I just wanted my program to be event-driven rather than polling.
Never mind, since its not impossible. I'll go with queue then.
Many Thanks!!
Message 7 of 12
(4,513 Views)
why do you think it's not event driven if you use a queue?
Mike
Message 8 of 12
(4,511 Views)
Event-driven, as it speaks, are triggered by events.
From my opinon, for queue, you need to keep polling it to get data.
Maybe you can help me by showing an "event driven" queue.
Message 9 of 12
(4,503 Views)
if you use the "Dequeue Element" with a timeout value "-1", then you wait til a new elment is available in the queue.
Mike
Message 10 of 12
(4,501 Views)
