Dynamic Displays
Hi guys,
I recently made a post similar to this topic:
http://forums.ni.com/t5/LabVIEW/Dynamic-panels-can-this-pseduocode-be-implemented-in-LabView/td-p/22...
The asyncrohnous call makes new windows which is not entirely what I had in mind.
What I want to do is have the user specify the number of instruments. Then the user specified number will indicate how many sets of panels to be displayed.
A rough sketch of what I have in mind is shown below.
Can this be done using the asyncrohnous call or is there another function for this type of thing?
William
(2,605 Views)
If by "Panel" you just mean a couple more controls, you can use an array indicator and set the size (number of elements displayed) programmatically.  Make the array element a cluster so you can mix different types of controls.
(2,602 Views)
