Dynamic Dispatch VI not in memory when built into PPL
Hello Everyone,
i have stumbled upon a problem which i need help from someone more experienced in this field: Labview gives me the following error when trying execute the Attribute.List.Get dynamic dispatch vi when I build the containing class into a PPL and try to execute it. The class must be in the memory because I have already inserted a few instance of it into the map collection which the for loop iterates through (as seen on the picture). The problem is resolved if I cast the object back to its parent object and try to execute its method that way. Can someone explain this behaviour to me? Thank you!
(2,493 Views)
I'm guessing here, but adding the class with the To More Specfic Class will link/force the class into memory and solve the problem. I bet much any function that uses that class would make it work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,415 Views)
