Dymo Label Software V8
Has anyone tried using the Dymo Label Printer with V8 software? If I create a label template using that software, I am not able to see the contents on my label. I used the Dymo Labview add-on and this works if I create a label using previous versions of Dymo Sfotware.
Message 1 of 17
(16,784 Views)
Accepted by topic author SenthilK
Issue resolved. Version 8 of DLS doesn't support dll interface. DLS has scripts for all the labels. I modifed the scripts to make it work.
Message 2 of 17
(16,740 Views)
Hi there,
I am struggling with the dymo software, to change a datafield. Does anybody has succes doing this, if possible send me a sample. Now we use the printlabel.exe programm, but it is kinda slow. All help is greatly appreciated.
Peter
Message 3 of 17
(16,657 Views)
Could you explain more about the problem?
Message 4 of 17
(16,648 Views)
Hi there,
I want to open a labelfile, change the barcode, and print the label using DLS 8. Now I use the printlabel programm supplied with the SDK kit, but it is very slow compared to DLS 7.8
Should be something like
Open label
Change datafield
Print label
I created a dymo high level driver (*.FP) and I am able to open a label and print it, but can't change data (yet) Shouldn't be to hard, but if somebody invented it already.....
Kind regards,
Peter,
Netherlands
Message 5 of 17
(16,646 Views)
Jippie a yee,
Breakthrough :
Now we are able to open a label, change data, and print it. Just don't know if all is done legally. Maybe I need to free some vars...
    #include "dymo_hlevel.h"
    VBOOL bool;
    CAObjHandle oHandle,bHandle;
    Dymo_NewIDymoAddIn (NULL, 0, LOCALE_NEUTRAL, 0, &oHandle);
    // Open label
    Dymo_IDymoAddInOpen (oHandle, NULL, LabelPathAndFile, &bool);
    // Change datafields
    Dymo_NewIDymoLabels (NULL, 0, LOCALE_NEUTRAL, 0, &bHandle);
    Dymo_IDymoLabelsSetField (bHandle, NULL, "BARCODE","101000547859", &bool);
    Dymo_IDymoLabelsSetField (bHandle, NULL, "DATUM","20110913", &bool);
    Dymo_IDymoAddInPrint (oHandle, NULL, aantal, VFALSE, &bool);
    Dymo_IDymoAddInQuit (oHandle, NULL);
Hope it can help somebody, or somebody knows how to do it better 🙂
Any input is appreciated,
Peter
Message 6 of 17
(16,640 Views)
I created a simple VI. Take a lok at it and let me know if you have any questions.
Message 7 of 17
(16,638 Views)
Thanks, but I use CVI, not labview. Can I view the VI in another way ?
Message 8 of 17
(16,636 Views)
You could probably use a run-time for L 8.6. I think its available in NI
Message 9 of 17
(16,634 Views)
SenthilK,
Your code actually runs on my PC with the latest Dymo drivers.  But, when I try to select any methods or properties in your code, there are none available.(?)  And, when I try creating another ActiveX refnum and browsing to "Select ActiveX Class", I can't find exact matches for the original ones in your code.  Do you have any idea where you found them?  Also, do you have any idea why your code runs on my machine, yet when I click on each of the Invoke Nodes it says there are no methods available??  How were you able to select the original Open, SetField and Print methods?  I'm totally stumped.
Message 10 of 17
(15,532 Views)
