Duplicate sub vi with the same global variable
This is a simple question, that probably was answered before:
I had a sub vi that uses a global variable. Now I need two of these sub vi's working simultaneously in a while loop. The problem is that they are both adressing the same global variable, but I need them to be isolated. How do I do that?
Thank you.
(2,768 Views)
Hi Ivan,
global variables are not the best way to solve this problem, because they can produce race conditions. A better way could be to use a "global functional variable". Its a sub vi which stores your data.
Mike
(2,766 Views)
Hi Ivan,
This Developer Zone article explains a little more background about why functional global variables are the best option for you. Happy coding!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,735 Views)
