Duplicate run-time menu item heirarchy
Hello:
Wanted to know if someone has done this already.  I have an extensive run-time menu in one application.  I need to programmatically duplicate the heirarchy of sub-menu items (several levels of child items) of one of the menu items so that I can place that entire heirarchy underneath another menu item.  Anyone do this yet before I start?
Sincerely,
Don
(3,322 Views)
There's an example that ships with LabVIEW that shows you how to use the menu functions to dynamically change the menubar. Open the Example Finder (Help -> Find Examples) and do a search for "menus". Open the example called "Dynamic Insert Demo".
(3,313 Views)
I know all about inserting menu items and do it in fact in this application.  The example you show is a brute force method to do the insertion that involves string arrays of known menu items.  My menu heirarchy may not be constant and must be read. What I was trying to find out is if someone may have developed a subVI from the menu fxs that programmatically reads the entire menu heirarchy for a given meu or sub-menu item, and then inserts that heirarchy under another menu or sub-menu item. The subVI would certainly use the 'Insert Menu Items' fx.  ....Don
(3,307 Views)
Well, you hadn't mentioned in your original message that you knew about the menu functions, so that's why I provided the example to look at. Since you know about the menu functions you pretty much know that's all you have as far as the menu functions. I guess if someone has already written a VI to do what you're looking to do they may be willing to share it with you.
(3,286 Views)
Right - this is actually not trivial to get the complicated menu heirarchy for several layers but it definitely is doable.  Yes, I am very familiar with the RT menu stuff as I am still big on using custom run-time menus as a way to not clutter up front panels when appropriate.....Don
(3,279 Views)
