Duda con Polar Plot with Point Options
Buenas. Estoy intentando realizar un diagrama fasorial. La cuestión es que quiero eliminar la escala que aparece en "Diagrama fasorial". Les envío una imagen. Saludos.
(731 Views)
Hi Maxifarias,
@Maxifarías wrote:
Hello good. I'm trying to make a phasor diagram. The thing is that I want to remove the scale that appears in "Phasor Diagram". I send you an image. Greetings.
Did you even try to look inside the PolarPlot VI? It's free to open…
You already set the plot color: did you try to set the grid color, too?
(679 Views)
