Dual monitors issues with Built application
I made a vi that uses both monitors.  I set the run time position to the second monitor on one vi and the first monitor on the other vi.  The vi running on the primary monitor calls the second vi on the second monitor vi the Vi Server.  This works great when working in the development environment.
But when I build the application, the vi that is supposed to be on the second monitor, shows up over the vi on the primary monitor.
Did I miss a setting in the Application Settings??
Kenny
Kenny
(4,575 Views)
Hello Kenny,
might be a bug. but the following code offers more options:
Ton
Message Edited by TonP on 09-02-2006 04:35 PM
My LabVIEW Ideas
(4,559 Views)
