Dual-Axis Digit Level LabVIEW drivers or commands
Hi has anyone has any experience in using Digipas DWL2000XY in LabVIEW. I really appreciate your help
(2,820 Views)
No doubt LabVIEW can do instruments control using USB, but you need to have the programming manual for Digipas DWL2000XY to know which command to send over the USB.
I have did a quick search on the internet, all I can find is a brief user manual: http://www.digipas.com/download/DWL2000XY%20Instruction%20Manual.pdf
Do you have more details on the instruments?
Beside this, you can get more detail information at USB communications using LabVIEW at the following link:
http://www.ni.com/white-paper/4478/en/
KH Lou
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(2,806 Views)
thanks KH Lou
yes I have seen the manual but there is no command in it. I want to use System Exec but as I mentioned I don't know what commands to send . The instrument is exactly what you found . The software is also developed in LV
(2,802 Views)
If you don't have a set of commands, you need to ask the vendor.
I don't understand at all your comment about using the system exec. If the vendor provides a program for the instrument, you could possibly interface with. Again, that is information you would need from the vendor. Have you asked yet?
(2,794 Views)
Hi, I would agree as Dennis, you need to contact the vendor to get the programming manual.
Even though you can use system exec to call the software, you still need the command shell from vendor (if there is) to do the customization.
KH Lou
(2,770 Views)
