Driver for JAZ Ocean Optics
Dear all,
I'm trying to find out whether there is a driver for the Ocean Optics "Jaz" Spectrometer to interface "Jaz" with the NI-cRIO.
I would like to use the Ethernet (TCP/IP) protocol but also the USB could be a solution.
Does anybody have anything on this?
Thank a lot
Fra_QS
(3,799 Views)
Hi Fra_QS
Please have a look at the ocean optics page.
They have the OmniDriver that supports LabVIEW 7.1 and above:
"OmniDriver provides drivers for LabVIEW version 7.1 and above to enable you to configure Ocean Optics spectrometers as real-time virtual instruments in National Instruments' LabVIEW graphical programming environment."
Spectroscopy Development Platform
You can download this driver here:
OmniDriver
Or you can use the standard TCP/IP functions in LabVIEW, but then you have to know the device specific commands for the communication.
Hope that helps.
Kind regards
Pixar
(3,775 Views)
