Driver Problem with Lecroy Wave series 3000 and HDO6104-MS Oscilloscope
Hi there,
I am trying to get wavefrom from the Lecroy HDO6104, Lecroy-HDO4034, Lecroy Wavesurfer 3024 and Lecroy WaveRunner 64Xi. I can connect most of them them through either TCPIP or USB via NI-Max software. I have VICP passport, IVI drivers, NI-VISA 19.0 and LeCroy Wave Series Oscilloscope Analyzer (driver from NI website) installed.
For my case, VICP::<Ip address> does not work when I put it on the VISA resource name using simple open, write, read and close block but USB address and device created from NI-Max works fine to return the read buffer and read count.
However, when I try to run the code for several time using USB connection, I get the following error:
Error -1073807343 occurred at VISA Open in VISA-sample-read-write.vi
How can I solve this?
Moreover the lecroy driver show me that there is an error in the property node.
Error -1073807343 occurred at Property Node (arg 1) in LeCroy Wave Series.lvlib:Write.vi
How can I solve this error?
I also get Error 85 when I work with the TCPIP protocol as VICP show me error. I always connect with LXI protocol btw.
Error 85 Occured at Scan From String Function in LabVIEW - NI
Solved: Error 85 Lecroy Scope - Page 2 - NI Community
I tried to fix the error with the above two links by insearting INR in place of %d like INR %d or CMR %d
then I also tried to change read, commad and execution error block with CMR %d, EXR %d, DDR %d. But these did not worked as well.
The tech support from Lecroy did not help me much except saying to use VICP passport command and LXI. I am using LXI protocol but VICP did not worked for me as it is showing error. USB connection is also showing the error as described above. I am new to LabVIEW platform.
Would anyone suggest me the possible solution?
Thanks in advanced.
Kind Regards,
Nick
(1,862 Views)
Hi Nick,
Were you able to solve your problem. I am encountering the same thing now.
conjectureP
(437 Views)
The original posted listed 4 different pieces of hardware as well as multiple different problems.
They also only have 2 posts in 2022 and never again, so it's unlikely they will return to answer you.
I suggest you make a new post, with information only about your actual problem.
(412 Views)
