04-14-2015 07:22 AM
After a week fighting to install DAQmx driver on my Labview 2013 (Win XP), i finally got it with NI DAQmx 14.1.
Everything is okay, i can run my VIs.
But, when i connect my NI USB-6221 (BNC) nothing happens.
I checked in MAX if it was communicating, MAX see the device but says that the device's drivers are not installed.
Then I checked if there was other drivers for this device on the website ans apparently no, it runs with DAQmx.
Have someone got a solution ?
Thank you
Solved! Go to Solution.
04-14-2015 08:58 AM - edited 04-14-2015 09:00 AM
Sorry for my English speaking, i'm coming from France.
04-14-2015
09:13 AM
- last edited on
04-11-2025
05:23 PM
by
Content Cleaner
The descriptions I see say that USB-6221 is a legacy device. That probably means support for it in later versions of DAQmx have been dropped.
I found this http://sine.ni.com/psp/app/doc/p/id/psp-84/lang/en
It doesn't definitively say what versions of DAQmx support the device, but that list appears to only go up to version 9.8.
04-14-2015
09:35 AM
- last edited on
04-11-2025
05:23 PM
by
Content Cleaner
Thanks for your answer.
In this document it seems that it should work : http://download.ni.com/support/softlib/multifunction_daq/nidaqmx/14.1/readme_fra.html
But maybe I should try with version 9...
04-14-2015 02:31 PM
You're right. That does show support for the USB 6221.
Make sure you've rebooted your PC. Other than that, assuming you had no odd error messages during the installation, I don't know why it wouldn't work. Unless by some chance that readme document is wrong.
04-15-2015 04:14 AM
Okay, problem solved with DAQmx v9.8 !
Thanks a lot !
