Drawing attention to an FP object DId YOU know this?
I remember using this invoke node when I did the Tunnel Wiring Wizard (now mercifully obsolete!).  If the user checked the "I Like to Watch" checkbox before starting the process, when I invoked the AddWire method, I would also set the case being wired to visible and do ObjHighlight on the wire refnum.  Slowed the process down, but gave you the comfort of seeing each wire flashing into existence across each case.
So I can confirm that it worked back in LV7.0...
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 21 of 21
(745 Views)
