Draw a line passing through two points
How to make a line in xy graph using two points and passing through these points (not manually please)
(3,497 Views)
Hi pdpanchani,
put both points into one plot and display the plot in your XY graph…
What exactly is the problem? Where are you stuck?
(3,475 Views)
If the line should extend past the two points, do a linear fit on the two existing points, pick two new x values bounding the desired range of the line and use linear evaluation to generate the respective y values.
(all this could also be done using simple math, of course) and make a second plot with a line interpolation style.
I assume you know how to make two plots on one graph?
(3,462 Views)
