Drag & drop
I need to do the drag & drop thing.
From a Tree Control I want to select a item and drop it onto the control or indicator of my choice.
item in the Tree Control will be signal comming from or going to an other system. I want to be able to assign theses signal to cotrols or indicator dynamicaly by drag and droping them to controls on my front panel.
Do I need to use ActiveX things... I ain't know nothing about theses things. If I do need to use ActiveX. Could someone give me where to begin. What should I look first? Is there a tutorial somewhere? A book that I should read... please help.
(3,480 Views)
This sounds like a neat idea... I can visualize what you want to do but have no idea how you could do that. I don't think you'll be able to do it using LabVIEW's built in tree control functions but that doesn't mean there isn't a work around that would do more or less the same thing. I would also be interested if you could adapt a solution to this to apply to two independent tree controls.
Perhaps you could read the value of the tree control and adapt one of the mouse-over examples to dynamically assign whatever is selected on the tree. This would require two clicks instead of an actual drag and drop but it seems somewhat feasible.
(3,480 Views)
It is a good work around. I will do that. That the conclusion I had too.
Thanks for your answer
Nitrof
(3,480 Views)
