Drag and drop multiple files on a path control?
How i can drag and drop multiple files on a path control?
Thank you ,
(6,294 Views)
Accepted by topic author Sarah_LAB
I think that you cannot drop multiple files on a path control (it's like dropping multiple numbers on a Numeric Control).  However, you can create an array of paths and drop different files in each member of the array ...
(6,291 Views)
Hi everyone,
As Bob said you cannot add several path at the same time in the same command. His solution is working very well and is the easiest.
I add my stone by adding another solution. You can drag several different paths to the same command one after the other in order to build an array of paths. I attached an example VI to this message.
Have a nice day
(6,237 Views)
Could you save the attachment in LV2015?  Thanks
(6,167 Views)
You should better put the stop button inside the event structure to handle the stop properly, and would be interesting too to place the "Tableau" indicator inside the loop, to see changes every time those happen. If you place it before the event structure, you could even see the initialization! And it is not necessary the timeout event in your case.
(5,447 Views)
