Drag and Drop Path Control Subpanel
In the attached .llb there are two files, a Master VI with a subpanel, and a SubVI that has a path control:
(full size image attached)
Is anyone else having trouble dragging and dropping into that path control? I am pretty sure this is a bug. If it isn't a bug I would love to hear the infinite wisdom behind the 'feature'.
[this is where my post will be edited to include the solution if found, or the things that were tried before moving on. Misery loves company but success is a party]
Keywords for search:
path control, pathcontrol, #path #control
SubPanel, sub panel, #subpanel
Drag and Drop, drag_and_drop #drag_and_drop
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
(3,732 Views)
Accepted by topic author szewczak
Solved. The problem was not the drag and drop opperation but the SubPanel. See snippet.
Just because the Top Level VI is running does not mean that the SubPanel is running....
(3,698 Views)
Also, Apologies I did not realize there was a timeout for editing original post. Hopefully I have not offended you, future reader.
(3,695 Views)
