Drag & drop to path control has stopped working ?
Bit of an odd one this. I've used the drag/drop to a path control many times before without a problem but I'm finding that I can't drag into a path control, but only on one of the two PCs I'm working on ?
I've got a path control in a VI, nothing else. The VI isn't running and I can't drop a path from explorer onto it. Exactly the same situation on the other PC (also running LV2017 under Win10) works fine. And yes ... Allow Dropping is enabled in both cases. 🙂
Any ideas ? Is there a global drag/drop setting somewhere or maybe it's a Windows setting ? Thanks.
(3,546 Views)
Drop doesn't work in 2 situations:
1. Path ctrl is a strict typedef;
2. Run LabVIEW as an admin.
George Zou
(3,509 Views)
Are you trying to drop a file's path when it is set to folders only? I haven't confirmed what happens in this case...
(3,506 Views)
George / Gregory
Thanks for the replies.
In answer to your suggestions ... no, the path control isn't strict typedef ... just straight off the Modern > String & Path palette.
LV is not running in Admin mode.
The Selection Mode is just as it comes off the palette ... Files and Existing.
Interestingly, I find I can drag and drop files from the Files tab within the LV project into a path control ok ..?
(3,483 Views)
