Download file from FTP : Error 1059 (Open File)
I need to download a binary file from cRIO FTP but I get an error 1059 Open file. The extension of the files to be downloaded is .dat .
Attached is a screen shot of my code.
Any ideas how I can solve my problem?
Thanks.
(5,486 Views)
1059 error indicates an unexpected file type.  Most .dat files are text files.  Try setting the binary terminal on the FPT [RETR].vi to be false.
(5,473 Views)
thanks centerbolt for your reply,
I tryed this issue but I still have a same error.
(5,455 Views)
Can you post your vi and an example .dat file?   I'll try this with my cFP.
(5,442 Views)
Hi centerbolt ,
Here attached is the document you requested.
Best regards.
(5,436 Views)
"local path" constant needs to include the target file name.  Won't work without it.
(5,427 Views)
Hi centerbolt,
Thank you, this solved the problem.
Best Regards.
(5,422 Views)
