Download Newport ESP301 Motion Control Driver
You can go to the NEWPORT Website under the following link, please scroll down till Resources >> Software.
There you can download the ESP301 Firmware Installer.
This directory contains a LabVIEW directory.
Greetings and Regards,
James.
James
Message 2 of 8
(9,951 Views)
did the method I suggested work?
If so, could you please mark the problem as solved?
Like that you would help other users finding a solution quicker.
Regards and Greetings,
James.
James
Message 3 of 8
(9,942 Views)
I have download the ESP301 Firmware Installer.
but the directory does't contain any LabVIEW directory.
Message 4 of 8
(8,377 Views)
Hi lizheng,
I have download the ESP301 Firmware Installer. but the directory does't contain any LabVIEW directory.
Well, you downloaded a "firmware" installer for that Newport device. "Firmware" is not related to LabVIEW!
Message 5 of 8
(8,374 Views)
Did anyone get the labview to communicate with the ESP301?
I found the labview file downloading the program ESP301_Installer_Wind10.zip in the site https://www.newport.com/f/esp301-3-axis-dc-and-stepper-motion-controller , and I found the Labview files C:\Newport\Motion Control\ESP301\LabView\ Source Code , but theses files does not work rightly.
Message 6 of 8
(6,605 Views)
I seem to have the same problem.
I wrote a Linux serial device driver for the ESP301 long ago, and I want to repurpose it. I was trying to write a Visa driver for serial/USB and I can't get USB to work.
- The Windows device manager shows it has no driver. Like you I tried the 2 zip files off the Newport website, but neither contains a driver. One is a motion program, the other a firmware updater (that can't seem to find the device via USB)
- Trying to use the NI-VISA Driver Wizard gives me a surprising:
The following errors were found when testing the device's compatibility with VISA:
[Device Id: USB\VID_14d&PID_3001]
ERROR -1073807174: Device descriptor error - null value for serial number [Device Id: USB\VID_104d&PID_3001]
ERROR -1073807174: Device descriptor error - unexpected bDescriptorType (expected USB_STRING_DESCRIPTOR)
Now, does anyone know how to install a driver for this device, or how to connect via USB to it, or how to get it recognized by Visa or as a generic USBTMC device ?
In the meanwhile I'll convert my old serial driver.
Message 7 of 8
(5,361 Views)
I seem to have partially figured it out.
The ESP301-GUI-V2.0.0.3 file (named as ESP301_Installer_Win10 on the website) installs a whole lot of stuff in C:\Newport\Motion Control\ESP301 (hey guys, it's Win10, not Win3.1 anymore !!!) and in the directory C:\Newport\Motion Control\ESP301\Bin\USB Driver\64-bit you can right-click on the usbuart3410.inf file and select [Install]. Disconnect, reconnect and it shows as a COM3 serial port, but via USB (some kind of virtual serial-to-USB adapter ?). The speed should be 921600 8N1. The terminator is \r.
Message 8 of 8
(5,351 Views)
