Doubt on XY graph VI
I had made a program to plot a graph of microstepps of motor against the intensity in volts. But the program have some problem such that the graph is not coming continous line .The previous point s will get deleted automatically only the new points will get plotted.SO what VI I have to use in between array and the XY plot to get continous values.
(2,499 Views)
It is difficult to tell what you are doing wrong without seeing any code, but if you use the build xy graph express VI, you need to uncheck "clear data between calls".
(2,489 Views)
