Doubt in a LabVIEW Code
In the attached VI, the Boolean buttons (Nickel & Dime) aren't working. Please explain the reason for this.
Previously, I didn't have an Event Structure. I had the code working as per the requirement but to associate the 'Initialize' and 'Clear' options, I had implemented the Event Structure.
Thanks.
(2,915 Views)
Accepted by topic author Ganny
You left out value changes for Dime and Nickel in the event structure.  Either create separate events or add them to your Initialise event.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,909 Views)
