Doubt about matrix or array
The english language has enough idiosyncracies to fill books. It is not better, and probably worse than most other languages. We are just used to it. 😄
Message 21 of 32
(1,319 Views)
I'm drawing the lines in white color. But can I change the color of just one line, like red one, and the others continuing at the white color?
Because when I try to change the color, it changes the color of all lines.
Regards
Message 22 of 32
(1,301 Views)
Are you referring to any particular post? What are "the lines"?
Attach a VI to illustrate what you are trying to do.
Message 23 of 32
(1,298 Views)
If you run my .vi, it will generate random lines at the graph.
That lines are data that I'm receiving, and I'm drawing them (I'm simulating a track that my car is doing). If I want to change the
color of a specific data, how can I do that?
I used the property node-> plot -> plot color. But it changes the color of teh all plot.
Message 24 of 32
(1,288 Views)
A plot can only have a single color. To display multiple colors, you need to graph to multiple plots.
Message 25 of 32
(1,282 Views)
Please do not post VIs which run forever!  Replace your false constant wired to the loop termination terminal with a front panel boolean control, such as a Stop button.
It is still not clear exactly what you want. With regard to the image below are you trying to change the color of the segment from X=5 to X=6 with a different color?
One way to do that is to have separate plots for each color. Initialize all the arrays with NaN (Not a Number). NaN values do not plot. Then as you read the data use Replace Array Subset to put the new data into the plot which has the color you want for that segment. You may need to put segment endpoints into both plots.
Lynn
Message 26 of 32
(1,278 Views)
Thanks Lynn. it is exacly that what I want.
I will try what you said.
Regards.
Message 27 of 32
(1,276 Views)
I would strongly recommend to use a 2D picture for this.
Message 28 of 32
(1,271 Views)
try this rough draft ...
Message 29 of 32
(1,264 Views)
uowwww... that code will help me a lot
Thanks!!!!
Message 30 of 32
(1,255 Views)
