Doubt about Fitting
Hi everybody
i have a little doubt about the "Linear Fit .vi"; i see the help page and i undestand that it takes a set of value X and Y and makes out the best fitting of the Y value. I tried to use it in a project and:
In the first block (the upper one) it takes a data set (X,Y) and makes the fit..ok!
In the second one (the lower one) it takes a ramp signal + noise data in the Y input and just the ramp signal in the X input.. how can he makes the fit?
It takes the same signal, how can it read the x value and the y value ? If i have a waveform in "dynamic data set" how can i separate the X and Y component? can i put the same signal in the X and Y input ?
I hope to be clear.. i just want to know how can the .vi read several kind o input.
Thank you
Nigeltorque
(2,986 Views)
I post the attachement in older version too..
Nigeltorque
(2,984 Views)
Is it possible to see the .vis ?? Is the first time i save one in an older version, hope you are able to see it!
Nigeltorque
(2,953 Views)
What values are you using for the model parameters? Start, End, Samples, Delta, Amplitude, Method 2?  The defaut values produce an Equation of Fit 2 with NaN.
The VIs in the 8.6 version came through.
Lynn
(2,936 Views)
Use a delta that is not zero.
(2,929 Views)
