Double integral X(t) (Accel to displ): issue with initial condition
Hi All,
To convert acceleration to displacement for impact of a projectile, I am trying to perform a double integration of the signal. The acceleration data is acquired as a 1D array at 20 kHz, with the Integral X(t) used to obtain the displacement. To validate the results of this, I used Excel to fit a 6th degree polynomial to the acceleration data, and mathematically integrated the polynomical equation twice to get the displacement (integration constants found from initial condiditons: at t=0, v = 3.63; x = 0. I am confident that this Excel calculation is correct as the velocity profile matched the approach and rebound velocities of the projectile (as measured independently by high speed footage).
To replicate this in LV (for future automated calculation, Excel method is time-intensive), I used the Integral x(t) function twice. However wiring the value of 3.63 to the initial condition input of the first instance of Integral x(t) did not produce the expected results as calculated by Excel, with the first integration starting at 0 rather than 3.63. By trail and error, a value of ~440000 wired to the initial condition produced similar results as Excel, although I can't figure out the relationship between 3.63 and 440000.
I realise that I can replicate the Excel work by fitting a polynomial in LV and integrating this equation, however I wish to integrate the actual data rather than the polynomial approximation. I know that this is possible, and I think it's either due to some manipulation of 3.63 to get 4400000 (is it something to do with the equation in Integral x(t) help menu y[i] = (1/6) sum(x[j-1] + 4x[j] + x[j+1])?) or else due to the inappropriate use of Integral x(t).
Can someone help me with this, if possible explaining how to arrive the value of 440000 from 3.63. Thanks.
Fiachra
Message Edited by FiachraC on 10-30-2009 11:06 AM
(6,944 Views)
Accepted by topic author FiachraC
Here is a hint:
440000 * 5e-5 / 6 = 3.667
5e-5 is your dt, and 6 comes from Simpson's Rule
(6,926 Views)
Thanks Darin!
(6,899 Views)
