Double Scale in XY Multi Plot
I really like the look of the graph used in XY Multi Plot.VI
Does anyone know if you can have two scales on the y-axis for this type of plot? How to implement it?
aleks.
(4,373 Views)
Yes, you can have two Y axes.  You right click on the one you have and choose "Duplicate Scale" to get the second scale.  You can then choose to "Swap Sides" if you want it on the other side of the graph.  From the Plot Legend, you can click on a plot to choose which Y scale will be used for that plot.  You might also want to play with grid colors or something like that to get some visual clue which plot goes with which scale.
(4,355 Views)
how to do if i change the scale Y0 the Y1 also change the same value?
(4,035 Views)
You asked the same question here. Please keep your question to one thread.
(4,014 Views)
