Double Pointer C Node Help
I'm working with the DLL for a piece of hardware I have, and ran across a command where I needed a double pointer to a char in order to get the data I actually want out. Unfortunately, NXG does not seem to have an option for double pointers in .sli files, so I end up pulling garbled data. The command is shown below.GNSS Command.PNG
In reading other forum topics, it would seem that in order to use this command, using the C Node and executing this command there would be the best way to do so. However, I don't know enough C to even do that. Could someone either walk me through the basics of C in order to be able to write the C Node or let me know if there's an alternate solution that doesn't require using a C Node?
Oh, and there was no .h file for the .dll, but there was a .lib.
Message 1 of 1
(2,525 Views)
