Dotnet system.array to method
Hello board
I am stuck in calling a dotnet assembly in LabVIEW. The final step is to pass a system.array into a method to have the result of the method call written into this array. I don't really understand how to do this.
Help is greatly appreciated.
The details are in the attached LV2011 example.
Dermot
(3,864 Views)
Accepted by topic author DAckermann
Is your LabVIEW code supposed to match the C# code in the comment above it?
Instead of reading the file as a text file, read it as a binary file and set the data type input to an array of the correct numeric type. When you read the file as a text file, it may convert the end-of-line character for you, which can cause corrupt the data. Also, it will be more memory efficient because you skip the unnecessary conversion from string to integer.
I don't understand exactly where your problem is, and the code doesn't make it clearer, but this link might help show how to convert a LabVIEW array into a .NET array: http://forums.ni.com/t5/LabVIEW/How-to-pass-a-Labview-array-into-a-C-NET-array-object/m-p/1992795#M6...
(3,841 Views)
Thank you for the link. This seems to show a solutionfor my problem. I didn't know how to instanciate a dotnet array in LabVIEW. And I have to say it doesn't look like fun 🙂
The file code is just for the testing. In the final application the jpeg is going to be as byte array in the RAM.
(3,831 Views)
