Domain Account Manager Not Launching
Hi All,
I am having an issue launching the LabVIEW Domain Account Manager utility - when selected from the menu toolbar (Tools>Security>Domain Account Manager...) the utility appears for an instance and then immediately disappears. When navigating to Tools>Security>Login... I get the following error message:
Unable to find any NI domain
Error code: -1967345663
OS and Network Services: (Hex 0x8ABCB001) Generic security error
After acknowledging this error I am presented with the NI Security Login window, where I can enter a User Name and Password, but the NI Domain option is empty and there are no options to select in the drop-down. The "OK" button on this window is also grayed-out.
Solutions I have tried so far are:
- Rebooting computer
- Restarting NI Domain Server & NI PSP Service Locator services
- Re-Installing LabVIEW
None of the above attempts have fixed the issue. Can anyone advise a potential solution? Any suggestions will be greatly appreciated.
Thanks very much,
TS
(2,674 Views)
Hi, TrentSteele
Can you provide some screen recording of the errors and steps for reproducing that error?
(2,353 Views)
I don't know if it's frowned upon to bump ancient threads, but I'm seeing this same behavior now. In the past, when I've seen this I believe it was a Windows security patch (from a customer's IT Dept.) which blocked certain ports. Having IT roll the patch back fixed the issue.
However, what are the options to keep a patch up but make sure that certain ports are kept open? What would these ports be that could be blocked causing the launcher to fail?
(1,322 Views)
