Doing Buffered Event count by using Count Buffered Edges.vi, when exactly do the counter start counting?
Actually i had posted this question previously, however i'm still very confused though i receive some reply.
I'm currently using Count Buffered Edges.vi to do Buffered Event count, with the following settings,
Source : Internal timebase, 100Khz, 10usec for each count
gate : use the function generator to send in a 50Hz signal(for testing purpose only). Period of 0.02sec
In the explaination of buffered event counting, it mention that counter will starts to count when detecting the edges(eg: rising edge) however in the counter control.vi it mention that counter will start to count as soon as i arm it?
so when does the counter starts counting actually?? the
time the counter starts to count is very critical for my application hence i need to be very clear regarding this issue.
Thks for all the help given from everyone.
lyn
(2,612 Views)
After you configure the counter, you arm it using the Control.vi. Once armed, the counter start counting the active edges on its source.
RamziH.
(2,612 Views)
