Does someone have a VI to acquire, display & store data from 2 or more 4472s
I am building up a dual (16-channel) 4472 (PCI) system using LabVIEW 6.1. I have found "Cont Acq to File (Binary" and "Display Acq'd File (binary)" that look like they can be extended to multiple boards but I hope that there are VIs already that will do the trick.
Thanks..
(2,624 Views)
_______________________________________
This section of the Discussion Forum is specifically for issues pertaining to the LV Datalogging and Supervisory Control add-on Module. You may want to post your query under LabVIEW General for faster response.
Thanks.
(2,624 Views)
Here is an example that shows how to synch PCI 4472 boards.
(2,624 Views)
