Does labview support bluetooth
I would like to know if there is any version of Labview (6.1 or later) that would support Bluetooth in it's set of instructions. The operating systems could be Windows or linux.
I also like to know what level of control I could have over bluetooth communications if any.
Jorge
Message 1 of 11
(6,030 Views)
Hello Jorge,
Yes, go to communications, bluetoth, there you have the vi's you need to handle bluetoth communication.
Hope it helps,
Paulo
Message 2 of 11
(6,024 Views)
Sorry, I forgot to mention the version, I think it's only after version 7.0, but I'm not sure.
In version 7.1 it does support.
Message 3 of 11
(6,022 Views)
As far as I know, BT is only supported in LV 7.1 on windows XP.
___________________
Try to take over the world!
Message 4 of 11
(6,011 Views)
Hi, I have a question about blue tooth pairing.  I like to pair a bluetooth dongle with a bluetooth modem.  Can they be paired strictly in labview (without going through bluetooth software)?  I'm using labview version 7.1
Billy
Message 5 of 11
(5,856 Views)
I have no experience with Bluetooth, so I suggest you do some more searching and look at the BT examples in the example finder (Help>>Find Examples) and if that doesn't help start a new thread for this question.
___________________
Message 6 of 11
(5,844 Views)
Bluetooth pairing is not supported in LabVIEW. I would recommend filing a product suggestion at the Product Suggestion Center.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 7 of 11
(5,827 Views)
Thanks.  It just a little inconvience to switch between labview and other application software.
BC
Message 8 of 11
(5,814 Views)
You can use this vi to programmatically pair with a bluetooth device, You'll need to download the 32feet.net  dotnet files for it to work
http://32feet.net/files/
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
Message 9 of 11
(4,868 Views)
Thank you so much.  I got it working.
Message 10 of 11
(4,861 Views)
