Does labVIEW have a function to solve the following math problem?
In Labview what is the easiest way to solve the following problem?
|----             ---|  -1       |--     ---|                |--       --|
|  1   1   0       |            |   a     |                |    x     |
|  1   0   1       |            |   b     |     =         |    y     |
|  0   1   1       |            |   c     |                |    z     |
|__             __|            |_       _|                |_       _|
from the equations:
     a = x + y
     b = x + z
     c = y + z         where a, b, c are know values.    The problem I actually have is a system of 9 equations.
Thank you.
Message 1 of 8
(4,321 Views)
LabVIEW includes a variety of linear algebra VIs that are useful for problems like this.  Take a look at the Solve Linear Equations VI.
Chris M
Message 2 of 8
(4,308 Views)
I dont really see how I can apply the VI that you suggested to solve my problem.
Message 3 of 8
(4,298 Views)
You have a known matrix, a known vector, and a vector you need to solve for given the equation Ax = b.  This is exactly the problem this VI is designed to solve:
With the values I made up for a, b, and c, the solution is [2, 3, 4].
Chris M
Message 4 of 8
(4,291 Views)
The values of the matrix are not known, so I'm trying to use an inverse square determinant to solve the problem.
Message 5 of 8
(4,286 Views)
I think you'll need to better clarify exactly what you are trying to solve.  Your original post suggests that the values of x, y, and z are the only unknowns.  If you're given a set of equations like (a=x+y, b=x+z, c=y+z) then that is indeed the case, and the solution I mentioned will work.  If that's not the case, then please be as detailed as possible in describing the actual problem you're working on.
Chris M
Message 6 of 8
(4,281 Views)
In my application I'm trying to find inductance values in a circuit. Basically the circuit is a three phase motor and I can only measure the paths between sets of coils. to calculate the individual component values. So I dont have coefficients to enter in the top matrix as you've shown. That's why I was trying to use a square determinant.
Message 7 of 8
(4,276 Views)
But those are the coefficients you provided in your example!  So if you don't have them, how were you able to provide them?
Message 8 of 8
(4,271 Views)
