Does changing FIFO size require recompiling the FPGA?
(1,563 Views)
Yes.
Only exception is the Host side buffer of a DMA-FIFO.  What kind of FIFO are you referring to?
ALE Consultants
(1,554 Views)
Host to Target - DMA
(1,538 Views)
(1,529 Views)
Where you are changing this FIFO size, are you configuring the FIFO project item?
DMA FIFOs (regardless of the direction) have buffers both on the FPGA and on the Host.
(1,485 Views)
