Hi Atul,
we have made a application which uses Oneworld. We didn't use the database connectivity tool because we used ODBC and SQL.
We have some VIs to do database connectivity using ODBC functions. So you have to know SQL as language and the ODBC functions. If you do not have this knowledge the database connectivity toolkit will make it easier for you.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
