Does RT 8.6 work with Labview 8.5?
I have Labview 8.5 on my desktop and I want to load RT 8.6 from an evaluation CD onto a target PC. Will they work together? I don't want to upgrade Labview on my desktop because then I will have to downgrade once the eval period runs out.
Ben
(3,256 Views)
No. You always need the exaclty same version of LabVIEW RT like from your LabVIEW.
Christian
(3,253 Views)
Accepted by topic author BenYL
I have several Labview version on my PC. They can work side by side. But they can not share source files, or toolkits. So I guess you can install Labview 8.6 in eval mode, and then Labview RT in eval mode. Then you make a copy of your 8.5 code and store it in a separate folder, for test driving the RT system. After the eval period you simply uninstall Labview 8.6 and the RT module.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,240 Views)
Thanks guys! Maybe I will load new Labview 2009 into my desktop and target for a month to test it out.
(3,221 Views)
